gerelmx1986
Any comparisons between this and the XBA-H3? Sold off my H3 not too long ago bcos the bass overpowered the mids too much, even with the vent mod.
I did the same and got instead the A3's
I want these! What will they cost and when will they be available?
These cost 30k yen (~$250), and already available in Asia. No info on when they'll come stateside though.
You can always get it immediately from Amazon Japan have it shipped to you via Tenso.
So guys I am considering getting either these, the older XBA-A2, or the Audio Technica ATH-IM02 or IM03 as my next big IEM purchase. What are your thoughts on the matter, everyone?
Depends on what you're looking for. A2 seems like a bassy, warm and more refined H3 (which I hope solved the bass bleeding into mids problem), but I haven't listened to it yet.
I've had the IM03 and sold it off. It is good, quite balanced, not as bassy as H3, mids are flat and treble is extended but smoothed out. Soundstage not that wide/deep though. A good all-rounder.
The IM02 won't be what you want if you want the Sony warm sound haha. It's more emphasised in the mids while lacking bass.
Heard the IM02 only once, preferred the IM03, then sold that for the CKR9 which I feel is the best ATH earphone currently. Cheaper too.
All said and done I'm still awaiting more impressions of the XBA-300.
What's the difference between the CK9 and the CKR9?
Singe BA vs Dual dynamic driver (Dual Phase Push-Pull Drivers)
And what does the CKR9 sound like, in terms of its signature and tonality?
I personally found CKR9 to be too forward in the upper mid region, giving a nasal tonality to anything and everything. It was very obvious when switching from other "flatter" sounding iems. Once your ears get used to it, it all sounds good though as the bass is fantastically layered and the overall sound is quite resolving with good resolution.
However, I pre
These 3 are actually very different sounding iems.
XBA A2; Warm and bassy. Great for modern pop/rock with its boomy bass and sparkly highs. Somewhat improved from XBA H3 but I would say its lacking balance compared to IM02/IM03
IM02: Neutral to slightly warm sound, excellent bass for dual BA, nicely done overall balance. The most natural sounding of the Audio Technica iems in my opinion (CKR10 comes close). The smoothest also.
IM03: V shaped. Recessed mids, decent bass but the treble is not that good. It is sparkly and has quite a bit of presence but also rather harsh in the lower treble. Tonality is off as well.
I would suggesst you also look into the XBA A3, which basically is a much more balanced sounding A2 and performs a notch higher than all of the above. I have yet to try the XBA 300 but so far seems like it would be a leaner sounding A3. Hoping to try it soon.
