You dont need any more bass after you eliminate the foam filters. Believe me. These things are a lot of fun!!.
Have been considering removing the foam filters... Does it remove a bit of the haze in the sound?
I think the sound is clear and warm.Have been considering removing the foam filters... Does it remove a bit of the haze in the sound?
can anyone that have both tell me what's the difference between EX 1000 cable to 800ST one?
It means you can't use headamp more than 500mW to drive this IEM , this is its driver's limitation .What is the purpose of the 500mw max input ??? What does it mean ?
