As said before, some people made adapter for these, pretty nice a dn can be had pretty affordable when you have retailers that stock em (I can have one here locally for 25-30$ from 2pin to MMCX)Hey all. Just picked these up after struggling to find a good iem to compliment my 1770 and R6. These are the first set that have good bass for my-- bass head bass that is still clear and isn't muddy. Great soundstage, too. Maybe it's the weird style, but these actually fit my ears better than all the Chi Find type iems. I really like them. Of course, it makes me wonder about the EX1000, but I couldn't find a pair as it's discontinued.
Best so far, but I do think maybe the KPE had a bit better clarity, but I prefer these overall based on fit and bass impact. I'm going to try the tape mod now and hook them up to the ES100 I ordered.
One drawback: hate the cable. Upgrades? Maybe a balanced one? These have that locking mechanism, so I assume they have to be Sont cables only.
Thanks
Josh
It doesn't really leak. It's still an IEM with small ish port on the side after all. At least as long as you don't listen to deafening volume that is.Hi, how bad is the sound leakage on EX800? would it bother someone sitting next to you in a plane?
thanks, Jose
I've tried a couple, the stock hybrid doesn't really work for me, I preferred the old Sony Hybrid with foam insert (came with my XBA A3), comply, and some RHA tips I own. I ended up putting a Spinfit on it tho, still deciding between it and spiral dots, but I had those onthe A3 so Spinfit it isHi all, just wondering, what's your fav tips for ex800st?
Impression: I'm too used to A3vs soundstage maybe, but the 800ST's doesnt have that big of a soundstage IMO, I think it's comparable to my IM04, bigeer than Shizuku, smaller than Adagio, what surprised me isn't that tho, it's how open it is, I sometimes feel like I'm not even wearing IEM with these, it's pretty ideal for when I want some awareness, listening indoors.
Otherwise fit is the same as my A3, tho the cable suck balls, it's thin, easy to tangle and long, 10-20cm longer than I want it to be.
I guess I'd buy some of those adapters.
