redrol
you can get adapters for them and use MMCX or 2 pin but the adapters are $35-$50 bux.. rich
congrats! The 800s are awesome IEMs. Legendary even.
@redrol , did you end up with a pair? They do have the right amount of bass, finally, but they don't have the detail and musicality that I remember the Kanas having. But hard to do real A/B from memory. Doing more comparisons today and tomorrow with the KZ ZS 10 and Beyer 1770.
Thanks. I did the tape mod on the 800's and then played with the EQ some more to bring the mids and treble up a bit. Treble is really rolled off I'm...not I may just be used to the Beyer treble spike.
With the KZ, I found that the silicone worked best, and tried the large, which enhanced the bass by making a better seal. Same with Sony. Wondering if I should try Kanas again with the larger silicone tips. Also curious about difference between pro and non pro.
Hi, how bad is the sound leakage on EX800? would it bother someone sitting next to you in a plane?Using them at gym now. With music on, these have been the best isolation this far. Can't hear any gum noise, as with Kanas, dm6, and KZ, there was a lot of noise. Stoked on these.
