jgazal
- Nov 28, 2006
I bought the Crowson Tactile Transducers directly from Crowson Tech.
Crowson Technology - Home Theater Tactile Motion Actuators - Beyond Bass Shakers
I have a Crowson 300B amp and 2 Shadow Actuators TES100SS (stereo) coming next week (...)
I have been using Crowson actuators under the couch for several years.
I would like to know if you have compared the Crowson linear actuator with inertial transducers like adx, aura etc.
What do you think about the tactile transducer equalization to tackle the inertial transducer resonant frequency?
5. Low bass really isn't practical with todays tactile transducers despite manufacturers claims of a frequency response down to 5 - 15Hz. Just like subwoofers, this is a displacement limited problem and not a RMS wattage limited one.
shake output ~= moving_mass * Xmax * frequency^2;
This is physics and there is no way around it. As the frequency gets lower you need to dramatically increase the Xmax excursion and/or the moving mass of the system. Think about it, all a transducer does is shake a mass. Either a bigger transducer or an array of a large number of smaller ones is needed if you want significant output at low sub sonic frequencies.
6. I haven't done any accurate measurements of this but it seems that the RBH and Aura transducer ring a bit after a transient occurs. I believe the transducers are not critically damped or even highly damped oscillators on a spring. This most likely (by definition) is due to their high Q resonant nature. Since you feel and don't really hear the transducers this is not as serious of a problem as it would be with conventional drivers. EQ-ing, which effectively lowers the Q, helps this.
http://www.baudline.com/erik/bass/tactile_faq.html
Stephen Smyth Collaborator on August 6
@Christian Hampp
Had not considered equalising the tactile output. It sounds like a few bands of parametric EQ (select centre freq, gain and Q) in the lower registers would suffice.
Christian Hampp on August 6
I have a seperate loudspeaker management system (Behringer DCX 2496) between the realiser and the headphone amp to do a subsonic filter for the headphones and to do equalising for my tactile transducer (its called i-beam) because this also necessary, at least with the i-beam because it has a natural massive 50 Hz peak and then it depends on where you mount the i-beam to your chair or sofa how you feel the different frequencies, and I think this will be similar with other transducers
https://www.kickstarter.com/projects/1959366850/realiser-a16-real-3d-audio-headphone-processor/comments
