Will the A16 allow you to change the video output to 1080p if you want? So I can use an Atmos audio track and 1080p output to TV? or is it just passing thru the video?
Here is what I am asking.. can the A16 tell Vudu (via Samsung BD-F7500 thru I think its EDID) that you are using a UHD TV even though I am using a Panasonic plasma in order to get the UHD selection of movie..have the movie stream to the A16.. the A16 use the UHD (Atmos) audio track and then have the A16 take the UHD video and output 1080p to my Plasma 1080p TV?
I would speculate that there is no video processing capability in the A16, same as there was not in the A8. It's an audio processor. Video is simply passed-through from HDMI-input to HDMI-output. This also allows Smyth to avoid dealing with compatibility issues between video components, AVR's, etc. so that if you have problems then it's up to you to deal with it.
I had a compatibility problem with my HDMI-enabled A8 several years ago when I first bought it, trying to use its HDMI-output to pass on video from my Oppop BDP-103 source to my Yamaha RX-V867 AVR, which had been fed to the A8 from HDMI1-output of the Oppo. Just didn't work right, and I was not getting multi-channel audio delivered from Oppo to the A8 but rather only 2-channel stereo. HDMI handshakes involve all the devices in the chain, which is often frought with surprises.
My solution was (as it will be with my upcoming A16) to use the Oppo in "A/V split mode" and then feed HDMI1-out (video-only) of the Oppo to feed the AVR for pass-through to my Panny 65VT50, and to use HDMI2-out (audio-only) of the Oppo fo feed the A8.
My A16 setup will include an Oppo UDP-203 (same dual HDMI outputs and "split A/V mode" capability as with the BDP-103). Once again, HDMI2-out of the 203 will feed audio-only to the A16.
And once again, HDMI1-out of the 203 will feed video-only to the new AVR, which is a relatively modest 4K-capable Yamaha RX-A860. To deal with potential video problems since I don't have a true HDCP2.2 display with HDMI 2.0a/b connectivity but I might still want to at least view new UHD content (admittedly not in true holy grail 4K60 4:4:4 600MHz), I've also purchased an
HDFury Integral to accomplish the appropriate down-conversions required down at the end of the video chain, hiding the 4K format limitations of my 31" Eizo CG318-4K monitor to the A860 and upstream UDP-203 source.
It seemed that the $250 price of the HDFury Integral was a fair price to pay for its needed "HDCP doctor" functionality, until such time in the future as I might actually acquire a true "holy grail" UHD display capable of genuinely receiving and displaying the latest UHD/HDR video content. But this whole subject is in the video world for me, not the audio world and my expectations out of the A16. I'm more concerned at the moment about finding some place here in LA to go get an Atmos measurement and PRIR created, in order to make use of this new audio capability via Realiser.
I don't expect the A16 to address any 4K-related video issues (or any other video compatibility issues for that matter), which is exactly what the HDFury Integral is designed to resolve. The A16 can only be expected to pass-through what video it does receive, be that good or not good news.
