Dinerenblanc
- Oct 20, 2014
As an update, I am really loving the Westone Star tips, these seal the deal with the JVC (copper?) cable attached. The cable definetly adds more warmth and smoothness as opposed to the stock cable, creating a similar sound signature as the FX 850s. The tips maintain the intrinsic clarity of the iems.
I am thinking of upgrading my Jvc cable to a higher quality copper cable. I see there are 93 spec and double helix ones. Any advice on which brand is better? I am very new to the cable world so advice would be awesome.
I take back all of the negative things I said a few posts ago about these headphones. They are blissful. I literally teared up the other night listing to my music...
haha I admit it, I once almost teared up while listening to my 846s too. As for cables, there's an assortment of makers to choose from. I got mine from Headphone Lounge, but I had some issues with the sound cutting out in the beginning. I ended up having to pry the o-rings on the connectors to loosen them to achieve a good connection. With that said, the cable is well built. If having to fiddle around with the connector doesn't sound appealing to you, you should consider ALO audio. They're quite expensive, but members have reported that no issues with their connectors. PlusSound is another maker with good feedback as well, and they're relatively cheap. Finally, there's Whiplash, and they're by far the most expensive. warrior1975 owns their $500 reference cable and he loves it. I'll post links to the four brands I mentioned below. Glad you're finally enjoying your 846s by the way.
http://www.aloaudio.com/cables/iem-cables
http://plussoundaudio.com/customcables/inearmonitor.html
http://headphonelounge.com/in-ear-monitor-cables/
http://www.whiplashaudio.com/cables/headphone-cables.html
