WhatToChoose
- Oct 5, 2014
mmmm......+1 however, as some have already pointed out the detachable cable makes it much easier to replace the stock cable in case it malfunctions. Think of the hassle of sending back your entire unit to Shure through your dealer just to have the cable replaced.
That is kind of why detachable cables were implemented in the first place in general. Not sure why people are bringing up obvious info like this.
Now, with regard to Shure, there are 2 possibilities I can think of as to why they didn't make the cables detachable. Either 1) In the designing process (Jude said it started 8-10 years ago?) Detachable cables might not have been common, so shure designed the system around a fixed cable design, and stuck with it. Or, 2) the detachable cable needed would add unnecessary cost, be proprietary, and increase points of failure in the system.
Whatever the case, Shure had their own reasons, and this is the result. I have no doubt that the cable would hold up under normal use. And by normal I mean treating this thing like a newborn. A $3000 newborn made out of plastic and metal that can fit in your pocket.
