olor1n
The Man. The Myth
- Aug 26, 2010
The most surprising thing to me is the amount of distortion present. Through the HD650 I find listening to some 2011 chart songs unbearable. Even through crappy apple buds, I'm sure its still present. Take '6 foot 7 foot' by lil wayne as example. ( A bad song i know) His voice is peaking the whole way through.
Wow. Do you have the exact same dac as me? Configured in the exact same way? Do you use the same cables as well?
I'm sorry if I'm not swept away by your rave findings in the tube rolling thread. I don't believe I've stated anywhere that the Orange Globes are the be all and end all, as you seem to exclaim with regularity for the different flavor of the week tubes to your followers. I've also stated that my Amperex tubes don't have the same synergy with the rev.2 as the HD650 in my rig.
I stand by my praise of the Amperex tubes with the HD650 in my system though. Thanks for letting me know that what I consider incredible synergy is merely average in your estimation.
I'm sorry to interrupt you, but I'm looking at the Matrix M-Stage as my next amp - What do you guys use to feed your HD650?
My current setup is computer -> Asus Xonar -> NO resampling! -> Superpro 707 DAC -> Maverick Tubemagic A1 w. Mullard tubes. Any suggestions for a new amp without breaking the bank? Not looking to spend more than $400. I don't mind buying used but I'm in the EU, so there's a wall of tax to fight unless buying from within the EU.
Sorry should explained myself better, I own the 650's and am looking at the LCD2's as next purchase. Some very helpful points though thanks
Well that just makes life 10x easier. Just save up, buy the LCD2, hold onto both for awhile (at least 6 months), then decide which one you want to let go. Don't make the same mistake as I did and sell off your HD650.
Under-appreciated on these forums imo.
I actually find the HD650 very appreciated on here (HD600 a little less)
