It's a snow day for me here, so I'm just relaxing at home burning in my NOS RCA 6F8G on the BH Crack....nope, definitely isn't sounding boring to me!
How are you getting on with the RCA 6F8G?
Just cuddle up to the warm glow of the tubes...
Problem is though, I can't decide whether or not I should upgrade my SRG2s to the Ultra-Linear. I LOVE the Sennheiser veil and the dark texture of the 650 so I'm just worried that the ultra-linear with a bit more treble energy might mess up the reason I love my 650s
*snip*
Beautiful!! What is that gorgeous finish on the Crack??
Dxanex...
I love the finish on the base also...just wonderful. I'm working on mine now. Walnut with dovetailed corners. I may try to use maple as a contrasting color for the front and back and use walnut for the sides.
I wanted to build a "from scratch" base so that I could put a bottom on it and make it slightly bigger to allow for upgrades and bigger caps.
No problem
Here’s another diagram from Brysyon’s BHA-1 manual, although it may be a bit confusing if your using it as visual reference while soldering the wires, just make sure you follow the number scheme.
*Picture*
The HiFIman one makes it a much clearer as the right #3 and left #1 are in real life reversed on the amp's female xlr as shown below.
*Picture*
SPC is what I use on my HD650. I went from stock single ended, to SPC balanced. I'm not sure if the material or the balancing did it, but the improvement was greatly noticed. Most likely both upgrades share the credit...
At a show, and just let me say, you had better have $1000 sitting around you don't need before you listen.
