NZtechfreak
- Jan 19, 2012
There are male to male ones available a number of places (although it isn't necessarily easy to track them down). Which kind of termination do you need at the DAC end?
Good point. I need male at both ends but only the Note 3 is USB 3. Basically it needs to be tiny and very flexible.
Actually, what I really want is for a phone manufacturer to wake up and build a phone with a built-in hi-fi mode that will enable hardware within the phone to do the job properly instead of the user having to scour the internet for all sorts of accessories to do what should be a relatively simple job. Give me a Note 4 that's twice as thick, I don't care. Just give us the damn hardware to do the job properly. It only has to be a good quality DAC after all. There's a thousand high quality 3.5mm to 3.5mm cables out there.
The OTG termination, that goes into the Note, can be micro USB or USB 3.0, it doesn't actually matter. I meant what kind of male termination does the other one have to be? Micro or mini USB, or something else?
What kind of micro USB to micro USB connector is that? Would love to get one. Thx
I know this is so last year, literally, but I would also like to get one. What kind of money are we talking for something like this cable?
TTVJ have a micro to micro one for $19, Mimic cables will do a nicer looking one for similar money (but more for shipping), Forza cables will do an amazing looking one and claim all sorts of amazing audiophile benefits to how their copper transfers the same 1's and 0's and charge a fortune for it (like 75 euros). They can be purchased via a Taobao intermediary via Ebay too, but I would need to hunt the links I have for that.
Finding it in the USA is one thing. Getting it here is quite another. That $20 cable will turn in to a $70 cable in a heartbeat.whatever you are looking for you can find it on the internet
This one from your suggestion, TTVJ, looks good. Not too expensive either.
http://www.ttvjaudio.com/TTVJ_Micro_USB_to_Micro_USB_Portable_Cable_p/aat0000200.htm
Yep, I have that one, perfectly good. I also have one of the Mimic cables ones (I sourced the right angled micro USB connectors for them so they could make it, ha!) too. It's prettier and a bit more flexible, but sounds no different to me. The Alo one (and also the cheaper Forza one) do not seem like even remotely rational spending to me.
It's odd that I can't find male to male when I think about it. I mean, why not? Is it somehow more difficult to produce?
I think I'm going to go with the Toxic Cables one that Tukorocks is using. It's not ridiculous expensive and it's from here in the UK so no import duty to worry about. It's also sexy as get out. I just need to wait a bit to raise the money since I've already spent a fortune this month - AKG Q701, Head'n'fi O2 and ODAC.
My wife thinks I'm insane
