lawrecedent
- Dec 8, 2013
So which version of Lollipop are you running? I'll avoid the update if it loses usb otg compatibilty because although I use a dedicated usb music app to power my schiit mini stack at home I use the fiio e18 as a portable when on the go.
I have just Googled this and can't find anything which suggests the feature has been removed. In fact a couple suggested Lollipop now has native support for usb dacs. Could it be a fault with your mini usb cable? I had to swap mine out a while back after the pins wore out with the result being no sound.
