Latest Specs on the line:
[size=11pt]Logitech UE 900 Noise-Isolating Earphones Specs[/size]
- [size=11pt]Internal Speaker Configuration: 4 proprietary precision balanced armatures[/size]
- [size=11pt]Sensitivity: 101.2 dB (50 mV, 1kHz) [/size]
- [size=11pt]Frequency response: 20 Hz - 20 kHz[/size]
- [size=11pt]Impedance: 30 ohms, 1 kHz[/size]
- [size=11pt]Ambient Isolation 26 dB [/size]
- [size=11pt]Input Connector: 1/8" (3.5 mm) gold plated[/size]
- [size=11pt]Cable Lengths: 1219.2 mm (4 ft)[/size]
- [size=11pt]Sensitivity (mic): -58 dBV/Pa[/size]
- [size=11pt]Frequency Response (mic): 100 Hz - 10 kHz[/size]
- [size=11pt]Weight (cable and earbuds w/ eartips): 17.664184[/size]
- [size=11pt]Warranty: 2-year limited hardware warranty.[/size]
[size=11pt]Logitech UE 4000 Headphones Specs[/size]
[size=11pt]· [/size][size=11pt]Headphone type: On-ear[/size]
- [size=11pt]Driver units: 40mm [/size]
- [size=11pt]Impedance: 32 ohms, 1 kHz [/size]
- [size=11pt]Frequency Response: 20 Hz - 20 kHz [/size]
- [size=11pt]Sensitivity: 92 dB SPL (50 mV, 1 kHz)[/size]
- [size=11pt]Sensitivity (mic): -42 dBV/Pa re: 0 dB = 1 Pa, 1 KHz [/size]
- [size=11pt]Frequency response (mic): 100 Hz - 10 kHz [/size]
- [size=11pt]Connection: 3.5 mm (1/8 inch) [/size]
- [size=11pt]Noise Isolation: 7 dB [/size]
[size=11pt]Logitech UE 6000 Headphones Specs[/size]
- [size=11pt]Headphone Type: Around the Ear (Circumaural) [/size]
- [size=11pt]Driver Diameter: 40mm [/size]
- [size=11pt]Input Impedance: 50 Ohms DCR Powered Off, 1K Ohms Powered On [/size]
- [size=11pt]Sensitivity: 97 dB SPL/mW Powered Off, 99 dB SPL/mW Powered On, 1KHz [/size]
- [size=11pt]Frequency Response: 20 Hz -20 KHz [/size]
- [size=11pt]Analog Connection: 3.5mm (1/8 inch) [/size]
- [size=11pt]Noise Isolation: 10 dB [/size]
- [size=11pt]Mic Sensitivity: -58dBV/Pa [/size]
- [size=11pt]Battery Type: 2 AAA batteries (included) [/size]
- [size=11pt]Battery Life: Over 40 hours of listening on average* [/size]
- [size=11pt]* Actual battery life will vary with use, settings and environmental conditions[/size]
- [size=11pt]Two-year limited hardware warranty[/size]
[size=11pt]Logitech UE 9000 Wireless Headphones Specs[/size]
[size=11pt]· [/size][size=11pt]Wireless range: 50 feet (15 meters) [/size]
- [size=11pt]Headphone type: Around-the-ear [/size]
- [size=11pt]Analog Input Impedance: 55 Ohms DCR Powered Off, 2K Ohms Powered On [/size]
- [size=11pt]Sensitivity: 96 dB SPL/mW Power Off, 102 dB SPL/mW Power On, 1KHz [/size]
- [size=11pt]Frequency response: 20 Hz - 20 kHz [/size]
- [size=11pt]Connection: Bluetooth (2.1 + EDR) or 3.5 mm (1/8 inch) [/size]
- [size=11pt]Analog Connection: 3.5mm (1/8 inch)[/size]
- [size=11pt]Wireless Connection: Bluetooth (Apt-X, AAC, SBC, HFP)[/size]
- [size=11pt]Supported Wireless Audio Codecs: apt-X, AAC, SBC[/size]
- [size=11pt]Noise Isolation: 14dB[/size]
- [size=11pt]Mic Sensitivity: -58dBv/Pa [/size]
- [size=11pt]Battery Type: Rechargeable Lithium Ion Polymer battery pack (included) [/size]
- [size=11pt]Battery Life (Wireless): Over 10 hours of listening on average* [/size]
- [size=11pt]Battery Life (Wired): Over 20 hours of listening on average* [/size]
- [size=11pt]* Actual battery life will vary with use, settings and environmental conditions. Rechargeable batteries have a limited number of charge cycles.[/size]
- [size=11pt]2-year limited hardware warranty[/size]
[size=11pt]Some info on the UE9000 Bluetooth, this is a communication from UE to me through PR on some questions I had:[/size]
There are many audio modes for UE 9000 as listed below:
1- Aux input with Power ON
2- Aux input with Power OFF
3- Bluetooth Hands Free Profile (calling with your cellphone) called HFP. Labelled 'Bluetooth Headset' on Mac.
4- Bluetooth stereo audio called A2DP (Advanced Audio Distribution Profile). Labelled 'Bluetooth Headphone' on Mac. This RF transport protocol uses the SBC codec(standard BT stereo audio that is compressed), AAC (for Apple iProducts) and APT-X (uncompressed full band wireless audio over Bluetooth). All are included in UE 9000. APT-X is included on most of the newer Apple computers (Mac Mini + Macbook Air).
For modes 1 and 2 it is full bandwidth audio from the cable. (20Hz-20KHz) as the web specs suggest.
For mode 3 the audio band is limited to narrow band audio for telephony. Audio performance (specifically audio bandwidth) in this mode is a legacy audio standard defined by the Bluetooth SIG standard for phone calls. For now it is narrow band, mono audio similar to a landline telephone for both mic and speaker paths. HFP specs are publicly available though on the Bluetooth SIG website.
For mode 4 the audio band is full band (20Hz-20KHz) as the web specs suggest for each of the audio codecs. Depending on the type of source device you have streaming BT from you get varying amounts of compression. APT-X is the best quality being uncompressed. AAC is the next best from your i device. A2DP is the standard codec for BT stereo audio that has compression. UE 9000 will automatically choose the best quality A2DP codec available from your source to optimize you listening experience. UE 9000 will also automatically switch from A2DP music mode over to HFP when a call comes in. The converse is true when the call is ended.
Personally, I thought the UE6000 and UE9000 sounded pretty damn good passively on the wire. Noise cancelling they got a bit too bassy and loose for me, but they weren't bad. Review on InnerFidelity will be up soon.
