Eight hours later and I finally recabled my D1001. Again, the change seems to be subtle. I was a bit underwhelmed, but I do believe that the sound changed quite a bit. Everything does sound better, and I was just going to sell my HFI-780, but I noticed how similar the two sounded, and now I'm struggling as to what to do. To my ears there iisn't much of a difference between the two, but since I'm just a beginner with the audio world and all... I can see that my HFI-780 has potential, especially later on in the future. Did I expect too much from my recable? Or perhaps from the D1001 overall?
Anyways... as to my soldering experience. The most difficult part was definitely soldering the plug. There was barely any room for me to do anything. I'll take a pic of my plug when I get home in break, since I plan on redoing the plug. I had to tape down the plug with lots of tape, and heating the parts for soldering took a while since everything acted as a big heatsink.
Soldering the connectors in the Denon was probably the easier part. I was comfortable with the soldering iron, but I was probably not taking great care of my iron. I didn't have a sponge with me, so paper towel had to improvise. Good thing I didn't invest in an expensive one just yet!
As for the steps... desolder the stock wire/solder with braid, remove cable, insert small amount of solder (I used Cardas Quad Eutectic), tin the wire (next difficult part), and heat both the pad and the wire... and I get a seemingly solid connection. I must've reheated the pad like six times... The Cardas melted too fast and I usually end up with a blob.
Any thoughts? It wasn't too bad of a first time experience, and I can definitely do better if I add additional tools (helping hands, a sponge, and a different source of light). I'll give my D1001 some burn in time, since these had 300 hours of burn in when stock.
