Patrick82
Banned
- Mar 1, 2003
This time I went to bed with the window closed, there is still some cold air coming through the gap though.
It is -3.5 degrees Celcius outside and 20.0 degrees inside. Half degree higher inside temperature than yesterday, my thermometer is very slow though. My body is still little cold but I'm hearing WARM sound! I can't believe the night and day difference temperature makes for the audio system!
I'm hearing the same detail but in a different flavor, the detail doesn't draw attention to itself anymore, everything is very smooth. Sibilance is gone, whiteness and fake blackness is gone. It sounds kind of dull compared to yesterday. I'm hearing too much bass again! I liked the sound of 19.5 C inside temperature instead.
I need to build a temperature controlled box for my audio system.
I'm still hearing the extra detail. I have excluded most of my list and these are left:
- Extra rubber bands for isolation feet needed a couple days to break in.
- I moved all music to a dedicated harddrive. I changed my RAID0 setup from 2 drives to 4 drives (my 2 drive array was 50+% fragmented, my 4 drive array is 5% fragmented). Before I was using 3 drives in my computer, now I'm using 5 drives. It increased the wattage with about 25watts which gave more internal power supply switching noise. The current draw of Valhalla cables to the wall has increased as well so the whole audio system is affected.
- Turned off computer without turning off audio system (different combination of burn-in).
