YH-1 Modification changes.
Here's the revised damping stack from cup floors to rear of drivers:
1. Paxmate Ring on floor
2. All stock black damping felt removed from vents
3. Remove the stock driver damping (yellow open cell foam)
4. One 60 mm gauze disc notched for cup screw compartments and cable entry/strain relief
5. 20 x 5 mm fiberglass disc over gauze, centered over metal pivot dish
6. 60 mm Arctic Cotton disc overlays cup vents (nick n, Thanks for the idea from another mod; and for the Arctic Cotton!) notched for cup screw compartments.
I also notched a segment wider than cable entry/2 bottom cup screw compartments to expose 3 vents on either side of the cable entry area = Modified Bass Ports.
7. 50 mm Arctic Cotton disc mounted directly onto the back of the driver, secured with little strips of double sided tape
I am amazed by the SQ tuned for my preferences:
Good Bass Extension and texture. No Boomy Bass Bloat.
Clear, smooth, lush mids.
Good Treble Extension with air, shimmer, and detail...no sibilance.
Balanced from top to bottom.
Damping Stack (cup floor to rear of driver):
Paxmate Plus Ring in cup floors
Black Dot = Notched Gauze
Green Dot = Fiberlass
Red Dot = Notched 60 mm Arctic Cotton
Blue 'B' = 50 mm Arctic Cotton
Stock Open Cell Foam and Vent Felts Removed/Not Used
Notched Gauze overlays Paxmate Ring
Fiberglass overlays Gauze
60 mm Arctic Cotton over Gauze and Fiberglass
50 mm Arctic Cotton taped directly to driver
Driver over Damping Stack
This example of YH-1 is in near-perfect condition. The pads are in good shape and there are not tears or breaks in the suspension headband.
The drivers are very clean with no corrosion. The cable is a bit twisted. I detached the cable strain relief and rotated the drivers to straighten the cables as much as possible.
This mod is Done.
BMF
Yamaha YH-1 Modification
The first picture shows what did Not work.
Pictures 2-4 show what Does work:
The SQ is really nice from top to bottom of the FR.
Lots of Fast bass with good extension.
Clear, lush mids with No Boomy Bass Bloat (B3).
Lots of treble details/shimmer without sibilance.
This Did Not Work:
30 mm Paxmate Disc in Cup Floor Under Stock Open
Cell Foam. This created too much damping pressure
against the back of the driver that squashed the bass.
This Does Work:
Paxmate Ring on Cup Floor with Fiberglass Disc inside.
Note: I removed both layers of Stock Perimeter Felt so
the rear slots are fully open. The back wave vents from
the sides of the damping stack.
nick n's secret sauce over Paxmate Ring and Fiberglass Disc
on Cup Floor.
YH-1 Stock Open Cell Foam over Paxmate Ring and
Fiberglass
Disc on the Cup Floors.
EDIT: Fiberglass has never bothered me. In this case, I don't know if it adds anything to the SQ since I did not try this configuration without it. I've used a thin layer of cotton extracted from a make-up remover pad with similar results. Angel Hair may work, too.
I failed to mention that I placed a layer of gauze under the fiberglass. The fiberglass is effectively sandwiched between the gauze and the white felt + stock yellow open cell foam and contained within the Paxmate Ring so it isn't going anywhere. As shown in the 3rd and 4th pictures, I removed both layers of the stock black felt segments exposing open rear cup vents. The back wave vents through from the sides of the damping stack and then out the rear cup vents (slots).
The SQ from this YH-1 modification is some of the best I've heard and comes close when directly compared with current production planars. I doubt that I will open them, again. I'm going to try this same damping stack in the HP-50A.
