ekrauss
- Oct 23, 2010
I have been for a while, connected via XLR. Nice upgrade to the HA-1.Anyone running it paired with the OPPO HA-1 ?
No, Sonica DAC as a DAC, HA-1 as a headphone amp.Oppo Sonica DAC for A to D? Not really designed for that. Its an afterthought free feature thrown in using a mid-fi chip PCM1808 that will make analog always sound inferior to digital! Like the Sonica outputs, the AtoD goes through electrolytic capacitors.
How many user-selectable filters does the Sonica Dac have?
ZERO.
The ~$800 Gustard X20uPro (dual ES9028pro chips) and the ~$300 Breeze Audio (single ES9028pro with swappable op amps) both offer the following pre-set filters:
For PCM, the display reads FIR Apodizing (best to my ears), Brick wall, M-sharp, M-slow, L-sharp, L-slow, and Hybrid.
For DSD, the display reads IIS 47K, 50K, 60K, and 70K.
We don't know what filters Oppo choose, and in an email response to a poster, Oppo said they don't plan to offer any filter choices. Its sort of moot as long as Oppo chose the apodizing filter because I never change PCM filters after finding the best one, but some people might choose different filters based on the quality of a recording. I've not played any DSD files yet, so have no preference on those filters.
So @PitBul34 which one do you like best? Oppo Sonica or Denafrips Ares? did you make a determination? you said you are keeping them both. Thanks!
http://download.oppodigital.com/sonica-dac/USB-0110/USB_DAC_firmware_windows.zip
Oppo Sonica Dac new xmos usb firmware !
You may want to read the Sonica DAC manual or look at the back panel again. I was responding to post #208, labeled as a test of the Sonica Analog to Digital conversion.
The Sonica DAC has one analog stereo input that feeds a PCM1808 A to D converter after going through electrolytic capacitors. That's why I wrote that ADC was just an afterthought feature. Its not a strong point of the product.
The ESS stock DAC filters do indeed sound mostly the same, but a couple stand out as superior. This on a modified Gustard X20Pro, which using 8 ES9028pro dac outputs in parallel for each stereo channel is like having the same or doubled channel stacking of the Oppo using only the 1 or 2 ES9038pro channels Oppo uses for each output. The Gustard has an advantage over Oppo by not having electrolytic capacitors in the signal path, discrete output buffers, and better, lower noise voltage regulators.
Additionally, filter differences were noticed using full range stereo speakers and not headphones, which more fully express image height, width, and depth compared to headphones. It may well be that using headphones, you couldn't tell any difference in any of the canned ESS filters or Oppo programmed/chosen custom filter into the DAC. Given the other software issues with gapless and all they try to take on with connectivity, I doubt Oppo took on filter design challenges. Oppo tends to whatever canned software chip providers given them.
In the end, the Sonica DAC does not sound as good as my Gustard DAC, so I shipped it back to Oppo this week.
