I told you differently today though. I sent you two PM's in a row but I think you only noticed the last one. Was wondering why you didn’t reply to the first one.
With the replacement cups and the damping inside those it should be easy to get the D7000 back to standard if I want it.
I ordered the stage 1 + stage 2 DIY package, seems like a good value to me and I don't need to send the phones and (possibly) import them back in.
Customs here are the same people that invented warm water, you know.
You have the Claro Walnut like MuppetFace. Does that classify under the soft or hard woods? Or put differently: did you opt for the dry and neutral sound or warm and romantic?
I have two pairs of J$ pads already, one pair is on the D7000. They are V1 or 2, not sure how to check that. I'll try with both the J$ pads and Mark's angled pads.
