The first post seems to have made the page formatting go awry, so I've removed a table, which seems to have fixed it. I'll just paste it here.
Lear LCM-5 Hong Kong | $945 ($1091 as tested) | Design: Acrylic shell with three sound tubes. The cable is detachable and the sockets are flush with the shell. | Cable: The cable is coated with a shiny black PVC and is a bit thinner than the standard twisted CIEM cable. 4/10 | Accessories: The LCM-5 comes with an accessory pack that includes an Otter box case, soft furry carrying pouch, cleaning tool, and cleaning fabric. Closing the case can at times be challenging if the carrying pouch isn’t used as the cable can get caught in the seal area of the case. 6/10 |
Drivers/Configuration: 5 BA drivers in a 3-way configuration. Single bass driver, dual midrange and dual treble drivers. | Build Quality: Very nice build quality with an excellent finish. | Isolation: Average for an acrylic shell. 5/10 | ||
| Sound Signature: Neutral yet capable with a detailed sound that is spacious. While on the analytical side, the sound isn't overly so and has a nice musicality to it. | Sonic Strengths: Great coherence and a good mix of analytical and musical sound without being overly bright | Sonic Weaknesses: Dynamics can suffer without a good source match. | |
Source Matching: The LCM-5 is amp dependent more so than DAC dependent as the LCM-5 requires a strong amp section to deliver good dynamics, but entry level DACs don’t hold the performance back too much. As the Clip+ showed, an amp isn’t necessary, but there are improvements to be had by choosing the right amp. | Listening Volume Performance: The LCM-5 has steady volume performance from low volumes to high volumes. The bass driver doesn’t need much power to kick in and still sounds adequate at lower volumes and doesn’t distort when the volume is turned up. | Contact Info: | ||
Key words: | ||||
Summary: With a neutral presentation of the midrange, tame yet capable bass, and ever so slightly bright treble, the LCM-5 offers its own flavor of “reference” sound that I found to be more neutral than most other “reference” tunings. The LCM-5 excels in coherence across the frequency spectrum and has the ability to make less coherent competitors sound lacking. Imaging is excellent and the presentation of the soundstage space is very good leading to a realistic sound which doesn’t focus on any one part of the spectrum. While the LCM-5 is on the analytical side of things and has high levels of clarity, the level of detail recreated is average leading to a non-fatiguing sound despite neutral and analytical sound signature. The LCM-5 is a great option for those that want neutrality and clarity with a non-offensive top end. | ||||
If you like: the CK10, the LCM-5 won't disappoint, and with the adapter cable, the ER4 sound signature is achieved with better resolution | ||||
Links: My full review | Updates: |
