MarkL Mod made EASY! D2000 (possibly for D5000) template!
Mar 17, 2011 at 9:13 PM Post #32 of 56
Thanks for the template
I was just about to mod mine but after doing a bit of reading it looks like you should only dampen the earcups and the small bit of the rear driver only on the D2000
http://www.head-fi.org/forum/thread/452096/for-those-who-diy-markl-mod-on-d2000#post6110009
Mar 19, 2011 at 3:59 AM Post #33 of 56
Just did a partial mod as per the thread listed by Jonclarke above and previous comments by markl in this thread. My mod involved applying dynamat xtreme to the innermost ring of the rear of the driver, and to the back of the earcup (but not over the gray disk). I'm already using the JMoney ear pads, so I didn't need to do the taper mod. Thanks to coolchu01 for the template - it definitely made things much simpler.
I was a bit concerned that the mod would take away some of the lovely bass impact that the D2000 provides. Thankfully, its still there after the mod, but it seems more controlled now. Overall, a mod well worth doing!
Apr 5, 2011 at 9:08 PM Post #34 of 56
After trying lots of different combinations, I get the best sound from Stuffed earpads and dynamat extreme on the back of the plastic earcups only, with the gray disc and outer stuffing removed.
Apr 7, 2011 at 5:18 PM Post #35 of 56
After a couple more days i still have not got the sound i want.
The bass is tight and powerfull and they have great sound stage but i'm finding the cymbals too over powering.
Is there a way to tame down the cymbals?
May 15, 2011 at 1:32 PM Post #42 of 56
I'm not 100% sure that this is the latest template because I've had this for some time, but knock yourself out -
https://rapidshare.com/files/604206734/markld2ktemplate.pdf
May 15, 2011 at 4:52 PM Post #43 of 56
Ah, I was just about to come upload this... here is another link to the same template.
http://www.scribd.com/fullscreen/55491274?access_key=key-1u1yx7wf87lgnyycdhwn
I've used it to cut out what I needed to dampen the cups and it worked perfectly. Cut out the inner circle so it fits around that gray disk and along the diagonal lines for the screw indentions and I'd recommend doing a dry run and putting the dynamat in before taking the tape off to get an idea of how to best approach the task. It would sure suck to mess up somehow the first time and have sticky stuff all over the place.
EDIT: here are some more links to peruse before going through with the mod:
http://www.head-fi.org/forum/thread/299627/how-to-build-one-of-the-world-s-finest-dynamic-headphones-markl-denon-ah-d5000-mods/75#post_3912731
