- Mar 20, 2010
The bumps on the Q's.... I have a very sore spot on the top of my head....
This is gonna take some time to get used to again.
Has anyone tried dolby headphone with the ath-pro700mk2? It's supposed to have a lot better imaging than the m50.
Chico, I can't see how the extra padding wouldwork for me, because I already have to fully extend the Qs to fit my long head. Thats probably why I get so much pressure from the headband.
Not enough to return them though. The Qs have a sound that I wish the PC360 had. The PC360 sounds thin and boring in comparison.
Its too bad people think they are the same as the K701. They most certainly are not.
Problem is, I'm not good with my hands and the like.
Both my Q's cables are green.
BTW, I added Moon opamps for my NFB 5, which will give it a tubelike sound, which should be nice for the Qs.
I get the impression that you could get a little bit more length out of the headband by reducing the curvature of the brushed aluminum bits. I can't find as large an image as I'd like but it almost looks like the bumps are stuck onto the surface? If that's the case you might be able to just slice them off.
It uses one of these, right? Just three wires I take it? I'm not quite ready to quote a price, but I suspect I will be soon if you're interested.
