Just a little over US$580, or realistically around $600 outside of China if that was truly the price. That also easily get you a mid-end DAP all on its own.
That E7 is extremely expensive. I’m guessing that it’s supposed to replace the P6 pro?
Anyway, the way I see it is this: if the W4 matches or exceeds stuff near its price point, then why isn’t it a good buy? It’s more compact than both the ifi Griffon and Mojo 2, has similar driving power, has more intuitive controls than the Mojo and it’s more versatile vs Mojo (can connect it to laptops, smartphones, tablets, actually has a display, actually has usb-c, etc. ). If it has a way to adjust EQ, and brings some of the sound that the P6 Pro is known for then it’s a winner.
Anyway, the way I see it is this: if the W4 matches or exceeds stuff near its price point, then why isn’t it a good buy? It’s more compact than both the ifi Griffon and Mojo 2, has similar driving power, has more intuitive controls than the Mojo and it’s more versatile (can connect it to laptops, smartphones, tablets, etc. ). If it has a way to adjust EQ, and brings some of the sound that the P6 Pro is known for then it’s a winner.
One of the things I liked about Luxury & Precision is that their high end products looked luxurious. A rare and beatuiful piece of audio art/collectible. The E7 in its pictures looks like a common mid-fi DAP. Then we have the 4497 chip. It may be implemented with great supporting processing but I wish it had something newer? Better? Different ? Only time will tell.
