Using UERM today with the Geek Out 450, 1000, ODAC, & Leckerton 6S Mk. II. Trying more combos, no HD800 today.
Fast A/B not that easy as I have to let the Geek Outs fire up without any phones plugged in and moving the cables or inserting the phones can break the connection with the computer.
Made some changes to the System and Audirvana preferences/settings. Think I have the volume control figured out now after Larry's post #266 in this thread and the LH Labs Mac Instructions posted above. I am controlling volume with the
laptop's volume buttons and can see them affecting the Geek Out's volume slider in Audio Midi as well as the dial on the Audirvana player. I don't push the buttons on the Geek Out for volume anymore.
From Larry, post #266 (red emphasis is mine): "Thanks for this nice report. And the way you use volume is correct. Mac OS and Audirvana will be the master of volume control. And Geek Out maintain a local settings copy by these two buttons. When you reset the volume in computer, it will restore back to computer's setting."
Other settings help: http://geek.lhlabs.com/force/geekout/1040-geek-101-macintosh-set-up-guide.html
After changing settings and playing more with just the UERM today, it is no longer clear to me that the 1000 is better than the 450 for them.
I'll keep burning them in and will report anything else after some more time with them.
Also, anyone else getting any distortion or artifacts during play? Have an idea that it is the fast-switching that I am trying to do that is causing it today (not warmed up properly), plus the cable is getting a bit loose. I need to listen to <just one unit> all day to see what's what...
Was mostly enjoying music on Friday/Saturday nights, now I'm back to testing again!!
