- Oct 14, 2013
V4A never worked well with my Exynos Note 4
Hi,
I've been thinking about picking up some DT1350's, but was wondering if they put the V10 into High gain mode without cable adapter tricking things into Aux mode which many claim is high gain mode. I have some Oppo PM-3s which are not powered enough by "normal audio" mode, and improve with AUX mode, but not enough for my tastes. When paired with a Cayin C5 things get good. I'd like to use my V10 alone but am not sure I can get enough gain to feel satiated. Yes, I like Bass. I'd love to know your thoughts.
Thanks
Thanks Hiphopscribe, So the BD DT1350s are at 80 ohms, so yes, they are above 50 ohms, but will these put out good bass via V10 in high gain mode? Also, is the high mode and aux mode similar or the same? I don't want to get new headphones just to get the phone into high gain mode...unless that high gain mode is better than Aux mode, and is something special above and beyond aux mode. From what I gather, aux mode and high gain mode sound the same, is this correct? What are the best strong bass headphones that put the v10 into high gain mode, under $400, and under $200. Thanks!
Just use any cable with an in-line mic/remote (if you have one) to get normal power. Doesn't matter what the impedance of the headphones are when that type of cable is used; V10 always goes to normal.
You might be right about aux vs. high power. Initially, when I found the aux mode, I wasn't sure if it was as loud and dynamic as high mode. Hard to do an A/B comparison between them but, since mic/remote cables do not function with high mode, there must be some difference no matter how minimal.
Let us know if you're able to confirm.
Unfortunately I don't an in-line mic/remote, but the V10 does occasionally mistake my HD598s for having a mic, it pops open Google search, and in those instances it is normal audio mode. I'll have to pull them out an do the testing with them instead. I'll report back
I'm so glad I got to see this message, I will never buy any LG again.
My LG G3 has this incredibly annoying issue, and they still haven't fixed it in newer models... LG never again.
I have been experiencing this using my Etymotic ER4 and the V10. Stationary listening does not pose a problem but even casual walking will trigger the Google Now voice search.I am curious if I were to use an insulator on the location of the mic location on a TRRS plug will work to cease this undesired effect. Thinking of using either some heat shrink or some liquid electrical tape (spray or brush application since I have both...) will report back with findings. This way the modification is removable if needed and shouldnt cause any damage to the 3.5mm female housing.
EDIT: no dice, the even small material thickness does not allow for the plug to be installed, back to the drawing board......
Does the V10 offer a line out option?
I have to get them out of the profile. Dynamic bass set at 60%. Viper bass set to normal bass mode, set at max, which is 17%. Don't recall the other settings, I'll check them later.
No.
Yes, it does.
