I'm having second thoughts now. I was quick to jump to conclusions I suppose. After extensive testing of lots of my well known music collection. I've finally distinguished not just a difference but a subtle improvement. I had to admit i'm not hearing things either. It's just simply not something dramatic in my system. I'm happy it's not a step sideways or backwards.
The area i'm hearing improvement in specifically is the higher tones, approximately somewhere around 7-9khz. Percentage wise, 3-5%. It's just a touch cleaner/smoother in this area of my music. Not all music i'm able to hear these improvements clearly. So is it still worth the upgrade? That's a matter of opinion. I think I will be hanging on to this til the end of the month and testing more setups with this intona. A local guy who owns a known ultra noisy laptop is wanting to do some testing to see if this device fixes his issues. I'm not doubting it will.
But last night I was considering selling this and using the money towards something else. It's hard to justify such a small change and a large price. This would totally be justified if my system could take advantage of this, if it were noisy... it's simply not having ground plan issues, EMI/RF etc.
My PC spec's are not quite audio grade, but a nice mix between a gaming machine that remains audibly very quiet yet is quiet in electrical noise for audio grade type use. I will eventually have an LHLabs Geek Souce 1tb SSD / 1.2Ghz ARM Cortex-A9 Quad Core / 4G Ram / 2Gflash for OS / with fanless design, triple femto clocks (even usb3.0), Ultra Low ESR Power cap upgrade +Power Cap upgrade Plus (high speed PPS bypass power caps). I think the Source will be an ideal music server for my gear at a later date.
For now I will be using my PC as my audio server
Specs are as follows:
SOFTWARE OS + AUDIO:
OS Windows 8.1 professional 64bit / Jriver Media Center 21 / Darin Fongs Out of Your Head
GENERAL BUILD:
Cooler Master HAF XB EVO 2
*Asus Rampage IV Black Edition Motherboard X79
*Intel 4820K Ivy-E @ 4.5ghz - bus speed remains at stock 100mhz for audio stability (usb ocxo clock speed is 100mhz)
*Corsair Dominator Platinum 16gb 1866mhz (blue/white light bars installed to go with color theme)
STORAGE OVERVIEW:
Samsung evo 1tb SSD - 850 EVO (music drive)
Samsung evo 1tb SSD - 840 EVO (OS drive)
Samsung 830 240gb for games
Samsung T1 500gb SSD portable music drive for audio meets
Mechanical Archaic drives (5 total)
4Drive NAS Tower includes:
(2) Samsung F3 1Tb each
(1) WD20EURS-73TLHY0 2TB 64mb cache - video storage
(1) HGST Deskstar 4TB (HDS724040ALE640)
external enclosed - WD Book My Book Pro 1.5tb
COOLING SYSTEM:
ALL EKWB Custom Water Cooling - Indigo Extreme - EKWB Extreme CPU waterblock, GPU Classy Water Block, R4BE Water Blocks. - EK-DDC 3.1PWM EK-UNI Holder DDC Spider - Ice Dragon Cooling NanoFluid - over 50 pieces of solid nickel fittings of various types/angles/extensions for ideal setup.
(2)EK-Vardar F3-120 (1850rpm) High Performance Liquid Cooling Fan (EK-CoolStream PE 240 (Dual) Radiator)
(2) SilenX 15 db exhaust fans (EFX-08-15B)
(1) Noctua NF-F12 iPPC-2000 PWM Fan with Focused Flow™ and SSO2 Bearing for Rear 120mm Radiator (EKWB EK-CoolStream PE 120 (Single) Water-Cooling Radiator)
AUDIO OVERVIEW HEADFI/HIFI:
DAC:
Audio-GD Master 11 w/ 6db gain stage upgrade + Hdmi i2s input + 3M EMI Absorber AB5050S film added to many IC's, between R-Core Transformers and front panel Output connections / DSP, many specific areas for potential noise. Noise reduction caps for all unused XLR, RCA, Coax etc
CANS/MICS HEADFI:
*HifiMan HEX/Norne Audio Draug2 cable XLR 4pin balanced
*HD800/Norne Audio Draug2 cable XLR 4pin balanced
*Senneheiser G4ME ZER0/Custom hard wired Norne Audio Skoll cable w/ separate occ silver litz cable for microphone) 6.3mm SE for headphones and 3.5mm for mic
*OPPO PM3's/Norne Audio Zoetic cable XLR 4pin balanced
*Antlion ModMic 4.0
SPEAKERS HIFI:
Vanatoo Transparent One HIFI Speakers + Definitive SuperCube 2000 subwoofer - Blue Jeans Cable LC-1 Double-Shielded Low Capacitance Subwoofer Cable - Audio Sensibility Silver SE Digital Coax RCA
VIDEO / DISPLAY :
EVGA 780TI kingpin edition - EKWB 780gtx Ti classy waterblock -nickel
Dual Stack monitor stand
Base: Asus Swift 27" G-Sync Monitor pg278q
Top: LG Ultra wide 25" monitor (above the asus on dual mount stand)
OTHER STUFF:
Aquacomputing MCU controlled LED Lighting:
Apple Ipad mini 3 128gb for remote control of Jriver and mounted on flexible stand attached to desk.
POWER RELATED components:
Corsair AX1200 Gold 1200watt psu (ultra low ripple for smps / USB 5VSB - 5.6mV-7.2mV in load I use)
Pangea AC-14SE power cord -Cryo'd
Paul Pang V3 USB OCXO PCIE card - Paul Haynes SR3 5v powered - fine silver dc cable
The typical general specifications for the SR3 unit are (specs beat most other LPS/batteries like Teddy Pardo, Mojo etc)
4 times lower noise than lead acid gel batteries and around half the noise of an LiO4 battery.
Less than 30uV of peak to peak noise/ripple
Less than 0.2 uS transient response and settling time from zero to full output
Up to 2.5A continuous, 10 amps transient
Output stage bolted to chassis for heat dissipation
Low ESR energy storage and filtering.
Floating output to avoid ground loops
(hynes Sr3 5v specs finished)
Internal PC power filtration devices:
Eifidelity Sata Power Filter for each SSD (all internal drives are filtered SSD's, no mechanical drives)
Elfidelity PC HI-FI Power Filter card PCI/PCI-E HiFi PC audio power purification - PCIe
Eifidelity PC power fan filter (5 of them... yes, 5! one for water pump, front fans, exhaust fans)
External drives are in a 4 drive NAS tower and smps on another circuit than my audio gear.
Power layout:
separate
CyberPower Sinewave UPS - 900watt - CP1500PFCLCD to power PC Alone and ACInfinity SR9 fans for audio gear air circulation (usb powered from front panel of ups)
separate
external NAS drives and WD book drive on another circuit/outlet + Laser printer + Lamp on same circuit
separate
PSAudio P300 (balanced AC power that is also Regenerated into pure sinewave) for
Paul Hynes SR3 5V <SR3 powered by modded-Pangea AC14-SE Cyro'd cable> direction of flow(SR3>PPA3>LHlabs 2g split cable>Intona>supra 1m cable>U12
Gustard U12/Teradak DC30w 7v (DC30w powered with Synergistic Research Tesla T1 cable) direction of flow (U12>HDMI i2s DHLabs SilverSonic .5meter cable > M11)
AGD-Master-11 (powered by Modded PSaudio Lab Cable 6-gauge!!!, 1057-strand copper, SonarQuest Silver plated red copper connectors, Cryo'd) All cables treated with Caig Pro Gold DeoxIT
separate
Brick Wall 8 outlet audio grade surge protector
Vanatoo T1's, SuperCube2000
PERSONAL USE:
Aluminum Foil Hat
but honestly, with as much crap as I have installed in one area, I would think I would have a little more noise going on that would leak into my gear. Apparently not much at all. I'm pretty happy to say that. Usually the simple approach gives the best results. Oddly most laptops i've heard are the noisiest sources for audio. I think the Intona would likely benefit these type of machines the most. Especially if you are plugged into the charger for the laptop. Battery power is likely more quiet. OR, invest in a fancy Linear Power Supply for your laptop.
Which I honeslty don't know much about since my laptop is used for CAD graphics only, no audio purposes.
For those who ordered the Intona and had excellent results, could you share the specifics of your system and why you think it made a difference specifically?
