HiFlight
I have the pleathers but had on my head for less than a few minutes as the fit just did not feel right.
On another note, I had a little problem with my DIY cable so have been listening to the HE-6 with the stock cable with the SE adapter out of my Marantz headphone out. Like most vintage integrateds the HP out ,if I remember correctly, uses the same output as the speaker taps with a 330 ohm resistor.
Gone are the incredible dynamics and detail, frequency extension is reduced and I hear a lot more distortion as the sound is all mushed up together. Just my 2 cents worth, your drive and mileage may vary.
My guess would be that the 330 ohm resistors (which is probably close to the actual measured output impedance) is coloring your 50 ohm HE-6 resistance. I would think that your HE-6 would sound much better driven from the speaker terminals without the influence of the 330 ohm resistors.
Using the most commonly accepted guideline for driver damping, the output impedance of your amp should be no greater than: Headphone impedance (resistance) /8.
