- Jul 12, 2007
They are SMC connectors
http://shop.conrad-uk.com/components/connectors/hf-connectors/smc-plug-connector/
I have the pleathers but had on my head for less than a few minutes as the fit just did not feel right.
On another note, I had a little problem with my DIY cable so have been listening to the HE-6 with the stock cable with the SE adapter out of my Marantz headphone out. Like most vintage integrateds the HP out ,if I remember correctly, uses the same output as the speaker taps with a 330 ohm resistor.
Gone are the incredible dynamics and detail, frequency extension is reduced and I hear a lot more distortion as the sound is all mushed up together. Just my 2 cents worth, your drive and mileage may vary.
What kind of wire are you using? You should not lose much at all with the stock cables even with the SE adapter.
