- Oct 6, 2013
I know it's not what I should have for the B3, but it's likely more powerful than an iPod. I may get an E11k if the X1 isn't enough.
If you have your mind set on X1 and B3 Pro I, you don't need an amp to pair it up. As I mentioned in my X1 review, I had B3 Pro I pumping connected directly to HO of X1 with 50% volume setting. But to make it shine, just like if you want to make any IEM or full size can shine from X1 - you will need to switch X1's HO to LO and connect an external amp. Either way, investment in external amp is a good idea. If you are on a budget, E11k is a good solution or you can go even cheaper with Topping NX1 (better battery life, though don't think it has bass boost like E11k).
My suggestion, unless you are looking at a discounted X1 + E11k bundle, I would just get X1 and see how you like it with B3 Pro I. If you are happy, there is no need for an amp. But in a future you can always upgrade this modular system by adding external amp which going to make X1 shine for sure.
