MINORISUKE
- Jan 29, 2015
I've been listening to the Master11 with the U12 today and not seeing a reason to keep it. As the sound quality so similar to being literally the same. I've applied a reverse channel filter in Jriver to compensate for the channel reversal. Sounds basically the same now. I should be getting the Amanero Combo 384 on wednesday. And that should be an improvement above the Via USB32.
I don't hear an improvement with the Gustard U12 as much as I want to hear something. If anything I'm going to side on the loss of performance side.
I didn't have any issues installing it with windows 8.1
everything works great. I'm using Jriver, reversed L and R channels, and chose HDMI streaming for bitperfect. I switch back to normal settings when going back to Via KS Direct [ASIO] for my M11.
Worth a shot, but not an improvement IMHO. Likely with some of DACLadders personal tweaks it would be something special. I have only tested for about 4 hours now, but played all my favorite common songs I know very well. There is a very very very small difference.
I would consider paying to have these mods done just out of curiosity. And hold nobody responsible if it was damaged.
but that likely won't happen. I should just return the unit.
As is well known, U12 needs burn-in for 100 hours. Some are disapointed in the first few hours and sell their unit before experiencing its real sound.
As for JRMC output, I do not think "HDMI streaming" is correct, as the HDMI connector of U12 has nothing to do with HDMI standards (see my previous post). I use either [ASIO] or [Kernel Streaming].
