normanl
- Aug 27, 2010
I would actually say it is neutral.
The bass goes deep (If it is in the record).
My op-amps are all changed so i can't tell if the original Gustard will have the same result as mine.
Currently listening to Angel by Massive Attack and the bass is fast and deep with no bloat, vocals are not sibilant as well, which i can appreciate. The soundscape is very organic and separation is fantastic.
Will give other records a listen and report back, but this is def. listenable to me (Take note that my HD800s have the anaxilus mod as well).
What are your replaced new op-amps? Can you also please list the part numbers and the stores that you ordered? Thanks.
