genclaymore
You've got it right. The ANZ models are correct. Also correct with the placement. The 797's are single opamps that replace the opa134's and the 823's are dual opamps that replace the 5532's. Open her up and look closely. You will see the numbers on the chips. There is also a circle that marks pin 1 on each chip and a notch cut out of the end. Replace the chips with the same pin and notch orientation and you're done. Easy peasy, lemon squeezy.
Hows the 823 top end on your end is it bright or warm. as I looking for a op-amp that similar to the LT1469 but have 3Dish sound stage with tame Highs.While having tight accurate bass. That isn't a metal can op-amp and can be gotten in Dip-8 and doesn't cost a arm and a leg like the muses.
