chrislangley4253
- Dec 16, 2009
Machine vs Hands?
Quote:Seems like you've found the headphones, or IEMs rather that have the perfect FR curve for you.
I gave up and sock-drawered my V5s. 2 days of pink noise and the bass has been tamed and the initial harshness, present in all the Magnums I've owned when new, has mostly disappeared as well. They are sitting in V4 aluminium shells in a pair of 325is in case anyone is wondering.
This is the first I've heard of Magnum V5's out, did you do a review of these.
V5 = X. My initial impressions were that the bass and treble were rather strong, but they've settled down now. I'm waiting on a cable so I can do a V4 vs. V5/X comparison.
Nice...I hope you're liking the Magnums....when they popped up the classifieds, I PM'd lostMidrange, and popped off for a snack...twenty minutes later you had beaten me to 'em because I hadn't responded you bugger...no hard feelings though, mine should be here from Jin any day now...my Cabillas cups are waiting quietly on the shelf...
Hi all,
I'm waiting for my V5 & they will be connected to a Little Dot mkII. Is there a more recommended amp for these cans?
Thanks
I wholeheartedly recommend the Aune T1 (with an upgraded tube).
Can you please explain the difference between the Aune T1 Stardard Version 6N11, Aune T1 Upgrade Version 6922 and the AUNE Fashion T1 6922?
I like this amp but do not understand the differences. Thanks in advance.
The upgrade version means it comes with a better tube. I've never heard of "fashion" version...it's probably just an odd translation. Otherwise the units are identical. In my opinion, skip the upgrade version, then go and order your own 6922 tube. I personally like this one the best so far:
http://www.boiaudioworks.com/6N23P
But I also like this one:
http://www.upscaleaudio.com/products/6H23-%7B47%7D-6922-Type-3.html
and I have this one on order:
http://www.upscaleaudio.com/products/Amperex-7308-vintage-gold-pin%21.html
Edit: Also, so I'm clear...the Aune T1 is a tube DAC with a built in solid state amp. That means, you must use the USB input to get use out of the tube. The amp section is solid state.
can anybody help me out how to build a Magnum headphone ?i'm new in this but can't pay 2000$ for HP1000 right now.are v5's sound better compared to v4's ?i want the most lightweight and comfortable magnum as possible.thank you all'zI like all Magnum's but don't know which to get
