- Apr 9, 2011
Can FiiO upload a guide for how to get the E17k Working with ASIO drivers for DSD playback and 32bit playback. I've been trying to get these to work and to no avail.
http://www.head-fi.org/t/615404/downloading-and-installation-guide-for-fiio-e17-asio-driver-the-beta-version#post_8482654
ASIO were really only useful for a time when computers had low resources. And thus exclusive programs used it to give the program the audio quality that it was designed to.
It is highly recommended to use the default output modes instead of ASIO. Contrary to popular "audiophile" claims, there are NO benefits from using ASIO as far as music playback quality is concerned, while bugs in ASIO drivers may severely degrade the performance.
WASAPI is much better than ASIO. Use WASAPI And while it can't increase playback quality, it 'ensures' it to be bit perfect and has muting. Use it instead. Instructions below.
HOW TO CHOOSE PLAYER IN FOOBAR:
In Foobar, you can just check the drop down menu for Playback and then choose Output.
You just change the Output Device to whatever you want.
HOW TO WASAPI IN FOOBAR:
Download WASAPIhttp://www.foobar2000.org/components/view/foo_out_wasapi
How to install the component?
http://wiki.hydrogenaud.io/index.php?title=Foobar2000:How_to_install_a_component
Very easy.
Then restart and same steps as above.
Now in the output place...select WASAPI
PUSH or EVENT?
http://wiki.jriver.com/index.php/WASAPI_Event_Style
PUSH works with all devices while EVENT only with some newer ones. Use EVENT if you hear no audio problems. USE push otherwise. Data is the same for all. If you are unsure, just choose PUSH.
REMEMBER: This doesn't make music better. It only ensures it.
HOW TO SET SAMPLE RATE AND DEPTH
The E17K supports up to 96KHz/32bit
To get this, its pretty simple
1: Right click on your volume control and click playback devices
Then
2: set your E17K as default if it isn't already. Then click properties as outlined.
3: Go to Supported Formats. Uncheck ALL of the encoded formats. Check the sample rates that I have checked. The E17K should be able to do 32KHz...but audio enthusiasts buying this unit probably shouldn't have that sample rate.
4:Go to Advanced and set Default Format to what I have. It HAS to be 32bit and 96000Hz.
Then check both exclusive mode boxes
NOTE: This only works if you aren't using WASAPI or exclusive applications. If you use WASAPI. Your E17K will auto change to whatever the song is rather than have it defaulted to this.
If this helped you. Feel free to give it an upvote (bottom right corner of this post)
