nopietns
- Apr 5, 2006
audioengr,, You've worked with the North star models quite a bit, any ideas if the I2S signal from the Juli@ would be ok for North star M192 DAC?
Originally Posted by dahlhaus /img/forum/go_quote.gif I've found out something strange. My multimeter says the voltage of the signal is half the normal. The three clock pins are 1.65V while the data pin is only 0.85V. The multimeter reads 5V normally from USB. What can I do? |
Originally Posted by nopietns /img/forum/go_quote.gif audioengr,, You've worked with the Northstar models quite a bit, any ideas if the I2S signal from the Juli@ would be ok for Northstar M192 DAC? |
On the RJ45 connector there are 8 connection used in this way: 4 for the signals and 4 for digital ground. To connect the card to the DAC you need to have 4 signals SDATA Serial Data SCK Serial Clock LRCK Left/Right clock MCLK Master Clock |
Originally Posted by nopietns /img/forum/go_quote.gif Huh, when I emailed the North star design support on the layout of the RJ-45, the answer was: Are You sure the other 4 pins are not just plain ground? |
Originally Posted by nopietns /img/forum/go_quote.gif So are the 4 different grounds just a fancy design of the North star Transport/DAC? |
Originally Posted by nopietns /img/forum/go_quote.gif So, - If someone doesn't just tell me where to attach the 4 grounds, I simply won't be using the Juli@ => NS M192 trough I2S. |
Originally Posted by nopietns /img/forum/go_quote.gif Hey, I didn't mean to be rude or tell that You should feel sorry that I won't be using the I2S. I didn' know the word "fancy" is that abusive. It's just that if some designs use a common ground for all the signals, but audioengr says that each ground is for it's own signal (and I beliehe he knows what he's saying (at least when talking about North Star Design)), it makes me wonder how important the differentiation of the grounds are for the NS M192 DAC. |
Originally Posted by audioengr /img/forum/go_quote.gif The I2S cabling should have 4 grounds, even if they are tied to the same ground-plane at the soruce and at the destination. The wires should be twisted-pairs or coaxial cables with correct impedance to match the terminations. This is simply batteries and bulbs, not rocket science. The "ground" wire for each signal provides a separate "return" path for each signal. Remember, in order to light a light bulib, you need both a forward current wire and a return current wire. Same with digital, you need two wires. If you make all of the signals share the same return wire, then the signals will crosstalk onto each other. This is the case for the Perpetual and the Stello products. Not optimum. Steve N. |
Originally Posted by FallenAngel /img/forum/go_quote.gif Interesting, I've never seen it implemented any other way. Are you suggesting that the "optimal solution" would be to have 4 digital grounds? I don't see how that could actually work, could you please elaborate. Thanks |
Originally Posted by audioengr /img/forum/go_quote.gif Having modded a LOT of P-3A DAC's in the past (not anymore), and having several I2S interfaces that can drive this, I can give you some tips on this: 1) the P-3A needs 5V signal levels, not 3.3V 2) The inputs are terminated with 100 ohms to ground 3) MCLK needs to be 128Fs or 96kHz will not work (this is usually 256Fs (Fs is the sample-rate frequency)) You will probably have to divide MCLK by 2. 4) the input receiver on the P-3A for the I2S is a rather slow RS-422 receiver - (I replaced it in my mods with a faster device and changed the voltage to 3.3V) |
Originally Posted by audioengr /img/forum/go_quote.gif If the clock is running, your multimeter will only show 1/2 the voltage. Same with a data line. You need an oscilloscope to do this right, not a multimeter. You need to be able to see the signals and verify correct signal connections and good signal integrity at the terminators on the P-3A board. Steve N. |
Originally Posted by dahlhaus /img/forum/go_quote.gif is it normal that the voltage of the data signal is half of that of the clock signals? |
Originally Posted by audioengr /img/forum/go_quote.gif The average DC on the clock signal is probably 2.5V if the signal level is 5V. |
