wackyterbacky
- Jun 8, 2007
Your problem may be caused by other software that is running at the same time.
What is your setup on the PC? OS? Music player? Juli@ driver?
I have XP SP3. I use Foobar2000 0.9.6 beta 2 which I run in Realtime priority mode. I use the native Juli@ ASIO 2 drivers. I have a simple batch file that launches Foobar2000
Batch file information. Paste the following into Notepad, make any changes needed, save as YourFilename.bat on your Desktop:
@echo off
c:
cd "Program Files\foobar2000\"
start/realtime foobar2000.exe
Also, I run Juli@ drivers 0.979 which I think are the best for Windows XP.
I turn off all System Sounds in Windows Control Panel:
Start>Settings>Control Panel>Sounds and Audio Devices>Sounds Tab>Sound Scheme>No Sounds
I found that some programs (or websites) play sounds and those come through.
Sometimes just opening web pages will cause enough CPU cycles to hit 100% and that can step on the music player.
There is lots of info here and on audioasylum about PC setup for best sound.
@echo off
c:
