Sulbh
- Jan 12, 2014
By G5 you mean Topping G5? Does it beat all of these even if they are used in wired mode?I have BTR7, G5, Mojo, DTR1+, HM901S, SONY 300A, WM1. For BT, SG1 has the best sound quality.
These two products couldn't be compared together, they are completely two species.By G5 you mean Topping G5? Does it beat all of these even if they are used in wired mode?
Maybe it is not a good combo, because he1000v2 is a low sensitivity headphone, which is more suitable for a powerful source. I've heard it on a desktop AMP,It's great! I don't know if portable devices could driven he1000v2 well. I tried to drive the Denon D9200 24ohm, 105db. The volume needs to reach 3 o'clock. He1000V2 should be more difficult than D9200, so DTR1+ or other powerful AMP maybe is a good choice.I would be interested if anybody has paired the SG1 with Hifiman's HE1000V2'S because that would be my use scenario?
Did dethonray update it's firmware because lot of people were saying that it's measurements are very bad and dethonray was forced to update the firmware to get better measurements but it also changed the sound character for worse. Can you confirm it?Maybe it is not a good combo, because he1000v2 is a low sensitivity headphone, which is more suitable for a powerful source. I've heard it on a desktop AMP,It's great! I don't know if portable devices could driven he1000v2 well. I tried to drive the Denon D9200 24ohm, 105db. The volume needs to reach 3 o'clock. He1000V2 should be more difficult than D9200, so DTR1+ or other powerful AMP maybe is a good choice.
I saw MEASUREMENT on this thread too. I also worried about sg1 and contacted DETHONRAY. I was told that they were fixing hardware and software because of a small problem in mass production. So my sg1 was delayed more than a week, and finally I got the latest version. Someone mentioned that the change was worse?Did dethonray update it's firmware because lot of people were saying that it's measurements are very bad and dethonray was forced to update the firmware to get better measurements but it also changed the sound character for worse. Can you confirm it?
I have been a fan of D*RAY for several years. If you want to find a BT gear with good sound quality, just buy it directly. If you care about the pleasure brought by parameters, ASR is a good choice. I have AQ Dragonfly red , Mojo. This time, sg1 is more friendly to IEM, especially different firmware and different timbre. I use serenade because it is more suitable for my earphones.Hi can you compare it to some other players or DAC/AMP?
Quest! I like the colored glass balls! Give me five!Happy weekend, three favorite toys in 2022!The LO of DTR1+is very good. If USBDAC function is added to the design, it will be perfect!
The latest firmware can be downloaded from Dethonray's website: Downloads - Wirless AMP: https://www.dethonray.com/https-www...nt-uploads-2021-08-honey-h1-3-8-zipdownloads/Anybody knows where I actually can find the firmware update? The Netherlands dethonray only had firmware for other devices.
How about some comparisons with other players in terms of sound quality?I have the DTR-1+ and very satisfied with the sound quality, so I got the confidence to pre order SG-1 right after they released it, the sound quality is quite close to DTR-1+, but the convenience of BT make it took the place of DTR-1+ in my backpack.
I‘ve made the protection case for it, the frame is 3D printed with nylon, and carbon fiber plate for up and down side, now I'm not worry about any scratches on the nice aluminium case.
