Zeos has high praise for everything.
Dethonray Pegasus SG1 - BT DAC/Amp Combo
- Thread starter fjlabs
ThreatDown
Can someone who has purchased this test the bluetooth range please. Hoping its as good as Qudelix-5K and not as bad as a btr5.
Enjoying the Vivid and fatigue-free sound, two hours passed before I knew it.
The output of SG1 is not as powerful as DTR1+, but it still maintains very good control ability. I don't need to consider the performance of each frequency band. Everything is natural and pleasant.
When connecting to Sony 300A, I found that the performance of LDAC is indeed better than AAC, with more details and better sound stage.
Sulbh
- Jan 12, 2014
Hi can you compare it's sound quality to some other players or DACs?
I have BTR7, G5, Mojo, DTR1+, HM901S, SONY 300A, WM1. For BT, SG1 has the best sound quality.Hi can you compare it's sound quality to some other players or DACs?
Sulbh
- Jan 12, 2014
Is it better than Mojo? I think Mojo does not have Bluetooth.I have BTR7, G5, Mojo, DTR1+,
I like mojo very much. The main reason is that the design is very good, small size and good sound.Is it better than Mojo? I think Mojo does not have Bluetooth.
If SG1 is paired with earbuds and serenades firmware is used, Mojo has no advantage at all. The performance of SG1 is incredible. The sound is as smooth as velvet.
- Mar 21, 2007
Is it pretty easy to update and switch between firmwares? Just need to connect to a PC?
hongky
- Mar 13, 2013
How many hours you got from a single charge ?
Thanks
Thanks
According to quick start, it takes about 3 minutes and requires a USB cable to connect to a Windows system.Is it pretty easy to update and switch between firmwares? Just need to connect to a PC?
daorenmi
- Mar 14, 2014
It takes 3.5 hours to charge. Single end, the battery life is about 8 hours, 4.4 ,5 hours. I didn't have a special test, which may not be accurate.How many hours you got from a single charge ?
Thanks
The sound is excellent, except that the corners are a little sharp. IMO, the rounded corners like H1 is good. Everything else is great. lol.
TchaikovskiFan
I also get around 8 hours of usage time on a charge.How many hours you got from a single charge ?
Thanks
Who has ever used a Bluetooth transmitter with good signal? I would like to buy a Bluetooth transmitter with better signal for my computer. It can support aptX hd and LDAC.
FiiO BTA30 / BTA30 ProWho has ever used a Bluetooth transmitter with good signal? I would like to buy a Bluetooth transmitter with better signal for my computer. It can support aptX hd and LDAC.
Sulbh
- Jan 12, 2014
Hi can you compare it to some other players or DAC/AMP?It takes 3.5 hours to charge. Single end, the battery life is about 8 hours, 4.4 ,5 hours. I didn't have a special test, which may not be accurate.
