Deleeh
I don't quite believe that.
The other R2R-based dacs are more expensive but strangely do not have these problems.
The Spring 3 as an example, as far as I have read, does not have to stay permanently on standby to perform, even if the price difference is unfairly 3 times as high.
Apart from that, there are no problems with running it at the output simultaneously or individually.
Even from the Gustard R26 or Soekris Dac you don't hear this, so I think it's a design problem with the Ares.
The only explanation for this would be that Denfrips might have gone a different way with the Ares for cost reasons.
From a personal point of view, I listen to music very differently, sometimes for days or weeks and sometimes for a few days or weeks.
Unfortunately, I find that a bit impractical when the Ares is only there after 2 hours or maybe more.
You could possibly live with 2 hours by switching it on 2 hours beforehand in standby.
I could also live with it if it was only until it was at operating temperature.
Unfortunately, I have never been able to find out exactly how many hours it takes until it is completely warm.
I've only read about it, but unfortunately even the support team didn't give me any information.
The thing about not using both outputs at the same time is a bit of a comfort problem for sure, but also not necessarily time related.
But even then I don't see the reason to buy an additional switch box just to be able to separate the signal.
But even then you could almost resort to preamps, where a lot of things could go wrong in the overall chain.
Added together, you can then buy a better R2R Dac, so to speak.
But I'm still open to it if someone knows more about the problems the Ares has.
Maybe everything is exaggerated more than it actually is.
Except for the output problem.
