markot86
- Sep 9, 2005
sorry to hijack this thread, but have any grado/alessandro users used the headroom micro setup?
Originally Posted by nspindel Now where did I put that damn manual???? |
Originally Posted by rpaul Pity, as I had hoped to compare the complete setup to the Micro Stack this weekend. My 30 day period for the Micro Stack is up on Nov. 3rd... Headroom customer service was already closed by the time I got home, so I emailed 'em and hopefully they can get the DPS out to me via express service so I can spend at least 2 nights comparing the 2 systems. Haven't had a chance to try out the Home amp w/o the DPS, hopefully late tonight. |
Originally Posted by nspindel Wow dude, all I can say is that you must either be single or have a really cool wife! I pity your wallet. But I envy your ears!!! |
Originally Posted by TheSloth I hope the system update in my sig. doesn't tempt you any further than you've already gone... |
Originally Posted by TheSloth Careful with that USB. It's difficult to get a bit identical USB stream, and I found slightly, but noticeably lower performance using the USB versus Optical. Is your computer's volume/output set to maximum, etc.? |
TheSloth said:Careful with that USB. It's difficult to get a bit identical USB stream, and I found slightly, but noticeably lower performance using the USB versus Optical. Is your computer's volume/output set to maximum, etc.?
QUOTE]
Sloth, what's the deal with this? I'm using usb digital on 2 computers. One sounds really good, the other (laptop) is giving me a bunch of popping/skipping noises. As a computer guy, I don't quite understand how you could get bit-inaccurate stream that would affect sound quality that would otherwise be perceived of as good. If there are bits dropping from the stream, it would convert to garbage, not to music that sounds less full or anything that we would think of in audiophile terms. Dropped digits in the stream would more likely result in what I'm hearing on my laptop, correct? Popping and skipping noises.
I'm very interested in what the cons are to the usb digital stream. The pros are pretty darn obvious (low jitter, ease of use with computer), but I'm just wondering if I spent $20 for a usb soundcard with an optical out, would sound quality somehow be better? Because there's little point running an external dac like the Micro if you're not sending it an accurate stream.
