Dear Rob,
I would like to say again how much I love my Hugo which I have been enjoying in my car on the way to work.
So, there will be no battery drain if I leave it on, perminantly? I heard some people experienced a slow drain for about 36hrs. I'd like to leave it on and just need your assurence. Sorry to bother you, Rob.
I can clearly hear what the Hugo does in terms of what you have mentioned "Most notable was rapid rhythms being reproduced with breathtaking clarity - before piano music sounded like a jumble of notes, now I could hear each key being played distinctly. The next major change was timbre variations - suddenly each instrument had their own distinct timbre qualities, and the loudest instrument dominance effect was gone. "
This is clearly audible and it is making my commute much more enjoyable ! For me each instrument sounds distinct and clear, and there is no dominance effect. I have never heard digital replay this good.
I have some small questions : I am thinking of using the headphone out into a Din cable for my Naim preamp at home, is there any advantage to this instead of RCA? Do RCA plugs become loose over time (apparently, they do) since I am unplugging the Hugo daily from my main hi-fi to use in the car. And so the cable I am thinking of buying has a 9mm plug casing diameter for the 3.5mm headphone jack will this fit the Hugo?
How many on-off cycles will the switch last (hopefully enough), is it worth switching the Hugo off at night to preserve the battery? I know you said you don't yourself and have answered the question above already, but just asking about the on-off switch.
Thanks
