Lornecherry
- Apr 12, 2008
In our search for audio nervana I can say this.
I have both an offramp and ap1/pp. They both help almost any DAC it connect them too
But our hearing does adjust to sound with out the USB converters.
If you play the music with out them and then connect them the change is very apparent. However if you just at the music and stop thinking
About every detail it seems fine. What they do is fine tune the entire presentation from bass to treble
But mostly increase soundstage if in speakers. With headphones this is less obvious
I do not own a Hugo so I do not know how much it will help. But the above post makes sense to me
For the money the ap1/pp is better but the offramp has ore outputs
With either device the USB cable or a USB add on card does not seem to Matter.
So it's a good return. As I have a PPA USB PCI x card and psu and there PPA red cable
And I could not hear a change with it or connect red to the mother board USB. But without the devices there was an improvement but not as dramatic as with the devices.
I very much would like to listen to Hugo with my I device
Al
...very much watching your posts, as I'm looking very seriously at the OR5 (probably wait for OR6). I've recently been comparing my portable system (AK120 + Hugo) to my main system fully-loaded Overdrive SE DAC driving a Stax setup...and while not all that fair (the Overdrive DAC is over $6K, and the Stax walks on B&W P7 portable phones), the Hugo is certainly good value...and it's portable. I can imagine the 0R5 (or AP1 + PP) would certainly bring the Hugo up a notch. Jitter is the glare in digital...getting rid of it gets you closer to analogue with all the benefits of digital. IMHO.
I will say that the FPGA in Chord's DACS (I also owned a DAC64, Chord's original implementation), works, and works well. Paul McGowan's (PS Audio) new DSD Direct Stream DAC also uses the Spartan FPGA. I heard that at the Chicago show and it's the full system DAC to beat.
Paul McGowan, John Franks, Gordon Rankin and Steve Nugent (Empirical Audio) are all bringing digital closer to what it was really supposed to be when the CD was announced as "perfect and forever" back in the 80's. Maybe not perfect yet, but getting damn close to a good turntable setup.
By the way, the Overdrive and Hugo DAC sound completely different. The Overdrive is very special (airy, full, detailed with great Bass extension) and the only DAC (other than the PS AUDIO DSD) that can humble the Hugo for under 10K. That said, I'm sure adding a OR5 to the Hugo will close the gap significantly. Fun times are ahead indeed.
