alcyst
- Nov 15, 2008
I'm getting the same problem. The optical port seems so recessed within the casing that the optical connectors i have are not clicking and i am getting no connection.
I contacted Chord about this, they got back promptly and straightforwardly with;
" When new the optical connectors can be quite tight. You should be able to push the supplied cable in until it clicks. As long as it is a tight fit it will be fine and work."
