Steven121
- Aug 6, 2014
All Fidelios are open-back headphones. I've never tried the Mic on the L2 but given the mic on my Fidelio S2 earphones works with everything from gaming to Skype, I would think the L2 would be much of the same. As for buying it, getting both the stack and the X1 will be just under $500, and will be more than enough for your needs. Unless you feel the need to splurge, anything above that $500 budget is luxury at best.
Doing research is good, but I normally recommend asking for a few(2-5max) models based on the music you enjoy, then just pick one which will fit you best based on said research. Otherwise, you're just going to end up confused and not know which is which.
The Modi/Magni Stack is a little bigger than the size of my hands, so they should fit nicely beside your monitor if you are putting them near your PC.
Ok so to add to what you said here about the 2-5 max models are there any other headphones that are better than the L2 Fidelio or these are the best you think in the price range of 500-600$ for headphones i can buy the magni and modi aswell so i would be spending more but i just want to know my options.
Bottom line i just want a awesome sounding headphone/setup that i can enjoy music with and if i don't have to spend alot of money that is also a plus
