I would do what you are saying. that is exaclty what I have.
As you are playing using pc you don't need mixamp. Just use the cmss3d from your sound card (it is virtual surround just like dolby headphones from asus xonar or mixamp, being the cmss3d better than dolby headphones for a lot of people).
Buy A good set of 5.1 headphones either roccat kave, hpa2 or sharkoon xtatic analog, and a good pair of stereo headphones for instance sennheiser hd 595. Then you can play with both and see yourself what is better. If you like better the stereo set then sell the multiple drivers. that is the way to go.
I agree by both see which one works for you, then go from there....
Personally i would go for stereo
mcnoiserdc would go for 5.1 headphones or virtual surround sound
