Every once in a while I take a "peek" on Roc's development. I "think" it is still improving, but I would say in first 50 hours most dramatic SQ changes happened. But even now (cca 150 h) it sounds, as Brits would say, bloody good.
If this is how all properly implemented class A gear sounds - I should kick myself for not trying that sooner.
Even though it "strips" connected sources and show them "naked" with their flaws and traits - all headphones that I have tried with Roc were at their best behavior and performed better than what I thought they actually can. HD600, W1000 and K701. Single Ended (SE) that is.
Balanced headphones are something new to me. New and highly addictive. So addictive that, after HD600 "test retermination" with HD650 stock cable plus 4 pin Neutrik XLRs and "balanced burning-in" for a while - AKGs and ATs just got to be recabled as well.
...and to think that I wanted to get rid of those "old" HD600s...
...and I have no heat problems. Roc is just mildly warm to the touch. It could be the effect of holes on top and bottom of the amp. AFAIK Roc is the first A-GD component that has them.
...oddity: SE and XLR inputs sound exactly the same (CA DacMagic connected to Roc via both)! I can perceive no benefit (difference) of balanced XLR input over "classic" RCA. I am using A-GD cables on both.
Should also mention that four channel stepped attenuator - it is pure (23 steps of) quality. And exponential resistance scale is just right. K701 and HD600 are hovering around 12:00. W1000 around 10:00-10:30.
