Hi ccschua,
Yes, I've been playing with DSP-1 settings for quite some time and used to report in DAC-19 thread because there was very little action in this RE-1 thread.
So basically, I can just repeat my findings from the other thread:
- activated dithering (pin6=off; default) pleasantly "rounds the edges" and can seem less detailed
- deactivated dithering (pin6=on) let "raw details" through and can seem to have "more sparkle"
- activated PLL (pin1=off; default) pictures "3D stage" in front of you; instruments are positioned not just left and right, but they seem to have height and depth dimension on the stage; depending on their "3D position" and "distance from the listener" instruments are quieter and seem less detailed
- deactivated PLL (pin1=on) is hyperdetailed and "in your face"; the stage is left, right and "inside your head" (or immediately in front of you); all instruments and details are louder; this setting is very dependent on transport quality
The "3D stage" price you have to pay to get "hyperdetails on a L/R plane" with deactivated PLL setting is not an option for me. If you are into hyperdetails, there is a compromise though: set the filter attenuation to -50dB (pin2=on; pin3=on). The details are there, you regain some staging, you loose some dynamics, energy and focus.
Personally, most of the time it is dithering=off (pin6=on) and PLL=on (pin1=off) for me. While it is fun altering the sound with those DSP-1 settings, ultimately I've found I'm always going back to default settings (with mood depending exception of activating/deactivating dithering) which is excellent.
As for removing RCA coax wires (as per Regal's advice), I'm waiting for an order with digital hook-up coax, some Caddock resistors and Mundorf caps to tackle DSP-1 and whole digital input board of my RE-1 more substantially. Also, sorry but I am not into complicating things inside RE-1 and will not compromise DSP-1 performance/stability with convenience of having external setting switches... kind of like RE-1's spartan simplicity.
But... just to put a bug in your ear
... there are some rumors that DSP-1's software is being updated, and that there are adjectives describing this update as: more balanced, deeper, wider, clearer...
Have fun ccschua
