ccschua
- May 19, 2008
As to the DIP settings. the dsp1 v4.0 comes with manual settings.
I have run around my old motherboard in search of the jumpers (with holder for easy setting)
After much trial, I found again the recommendation by Faudrei suits me.
1. PIn1 ON (PLL is deactivated)
2. Pin 2 On
3. Pin 3 On (means I am now on -50dB attenuation)
4. The rest of the pins are default
I felt the dither ON has lost focus and enrgy and rounder edge. Musics flows smoothly with Dither Off rather than ON.
However my finding with Kingwa is that Dither has no part to play in Ref 1 because of the DIR9001. I wonder if the DIR 9001 can work to in 16 bit mode (padded with zero)?
2. Pin 2 On
