FauDrei
- Mar 6, 2007
It's worth checking the bias at least once the Phoenix has burned in IMO as mine had drifted from the default 15V. IIRC I set it to 18V for the LCD-2s and the result is fantastic. It changes the sound a little so is worth experimenting with.
I really like the changes using the new bias V setting...it's very subtle in nature (vs stock 18V) ...I opted for a compromise between the strengths of the stock V while adding a fair taste of the attributes brought to the table by the lower bias V .Thanks to both Curra and FauDrei for bringing these details WRT tweaking the amp in this manner to light. !!!!
As an aside I had not bothered to check bias V after the MAX mod (it never occurred to me at that time) so before getting into the various settings yesterday I did note what the settings were ( L channel was - 17.78 + 17.98, R channel - 17.69 + 17.92). That wasn't tool bad I suppose....getting these settings all uniform sounds much better (IMO and to these ears at least).
Peete.
Enjoy Peete.
I suppose those K42 and K40 are from e-bay? I might me sourcing them soon...
...and BTW & OT - Peete, if you are still in planning phase of diode swap project - do also consider Schottky SiC "zero recovery" diodes. I am pleased with my "stealths", but they do get darn hot...
X2, I tried the HE6 (balanced) and the LCD2 (SE) on the Phoenix and preferred the HE6 by a wide margin. I felt like the HE6 could've possibly benefited from more power, so I'm thinking the HE-500 might be a better match with the Phoenix.
I'm running my main system's amps ( 4 mono blocks and 1 stereo amp, 4.2 setup) off the Phoenix SE'd preamp outs, it's sound quality is fantastic dukja FWIW.
Peete.
Thanks for the sharing on your experience. One day I'll get to the bias...
On another topic, recently I used Phoenix as preamp to my NAD216 and then to power HE-6. The sound is good but not as good as I would like. Suddenly, I remembered that my previous experience with SE headphone output, which wasn't as good as balanced headphone output. So I wonder if the same principle also applies: the SE preamp output may not as good as XLR preamp out?
I'd appreciate someone has used balanced power amp (e.g. some Audio-gd offerings or others) with Phoenix may confirm my suspicion. If that is the case, then I'll need to hunt down a balanced power amp.
