PFKMan23
- Dec 31, 2004
Any idea of pricing on those?
Originally Posted by PFKMan23 /img/forum/go_quote.gif Any idea of pricing on those? |
Originally Posted by saisunil /img/forum/go_quote.gif Hi, I am considering getting the Ety4P recabled. Is there an improvement in bass after recabling? What other changes/improvements can be noticed after recabling work. I am assuming - the cable will be connected directly to the driver/speaker instead of going through a connector - thereby making it more transparent... Cheers Thanks |
Originally Posted by [AK]Zip /img/forum/go_quote.gif APureSound cables have NEVER used foil for shielding. All the V3 cables are cotton insulated. Carbon / Clear / Black are just outer sleeving colors and there is difference between them other than appearance. Thanks, Alex |
Originally Posted by GlorytheWiz825 /img/forum/go_quote.gif Do you mean there is no difference between them other than appearance? |
Originally Posted by HiFi FOR METAL /img/forum/go_quote.gif Alex you mention that your cables are not solid core, but are the strands individually coated in Teflon? Is there any strand to strand interaction? From what you are saying this method you are using sounds akin to some of the nordost coating techniques that they use. I know first hand that it is hard to strip the Teflon off of those cables because it is basically stuck to the conductor. Is your cable similar in this fashion? |
