NZtechfreak
- Jan 19, 2012
I prefer the black USB DAC/amp! Can't tell on design from only those pictures, but do prefer the thinner slab form factor for pairing with smartphones.
OK, thanks.
I'm concerned it could be a hardware issue since it worked fine before until yesterday. I haven't updated the firmware so I'm at a loss as to why it stopped.
Hi everyone!
A new product is coming... Do you know what it is?
Do you prefer the black one or the silver one?And how about its design?
I thought after firmware upgrading the native USB audio (i.e. Rocket Player or Tidal) is no more compatible with your USB DAC: hence the use of another third-party USB audio (i.e. UAPP).
I think some component of your setup is malfunctioning:
. Android device (particularly its USB OTG chip switching the Android device to USB host mode on the insertion of a USB OTG plug)
. USB OTG cable
. USB DAC.
Therefore, each component should be separately tested: Go to next test only if the ongoing test is successful.
. Test the USB DAC with a PC or a Mac:
PC >> regular USB cable provided by the USB DAC maker >> USB DAC >> amp >> headphones
. Test the Android device and a USB OTG adapter with a simpler USB peripheral like a USB mouse or a USB keyboard:
Android device >> USB OTG adapter >> USB mouse
. Test the setup using the USB OTG adapter:
Android device >> USB OTG adapter + regular USB cable >> USB DAC >> amp >> headphones
If the tests are successful, apparently the USB OTG cable is not functional (i.e. pin 4 is no more well connected to pin 5), then fix the USB OTG cable or buy a new one.
Android device >> USB OTG cable >> USB DAC >> amp >> headphones
I have a galaxy tab 3 running kit-kat. Is it possible to input audio from a usb microphone with a host otg cable?
Hi everyone!
Man, can't get my JDS Labs ODAC to work with my new 6P. Have tried using this cable and a cheapy type c to type b adapter, no good.
Interestingly UAPP recognises the DAC being disconnected and suggests Linux can see it, but the phone refuses to boot with the DAC connected. So frustrating, used to work fine with my S4 and S5, failed to work with my S6 (someone here reported success with this) and now my 6P.
Has anyone had any luck with the ODAC specifically on the 6P? The DAC still works fine on my PC.
Thanks
What does "Powered by HiBy" mean?
Thanks
